Author Topic: Trouble Finding rca Speaker  (Read 381 times)
Offline SylvestreTopic starter
  • Helpful? 12
« on: November 04, 2012, 05:20:15 PM »
Hello everyone,
I'm having trouble finding a small speaker with an rca connector.  The speaker will be used to output the audio from a microphone.  It has to be fairly small to fit in my controller case.  I'm having trouble finding it on Google because there is a electronics brand with the name of RCA that coincidently sells speakers.  Do you guys have any ideas for search terms or products you've used before?
  • Helpful? 84
Re: Trouble Finding rca Speaker
« Reply #1 on: November 04, 2012, 05:27:51 PM »
fairly small
?? a bread box small or a hear aid small???
There is a audio amplifier between the mic and speaker, correct?
Why not just solder an RCA connector to the speaker leads.
Radio Shack (USA) and Farnells (UK, EU) have RCA plugs and jacks as well as many other electronic suppliers.
for example:
http://www.hosfelt.com/contents/en-us/d734.html
http://www.mouser.com/Search/Refine.aspx?N=12094737
What is it you really need?
« Last Edit: November 05, 2012, 04:49:06 PM by waltr »
  • Helpful? 12
« Reply #2 on: November 04, 2012, 08:36:01 PM »
I bought this receiver and transmitter http://tinyurl.com/b85fq57
I have a mic that plugs directly into the transmitter.  I was hoping I could find a speaker that could just plug directly into the red rca port.
Offline Gertlex
  • Helpful? 23
« Reply #3 on: November 04, 2012, 09:44:08 PM »
How big is your "controller case"?
fairly small
As a hearing aid wearer, I... find that comparison amusing ;)
I
  • Helpful? 12
« Reply #4 on: November 05, 2012, 02:53:23 PM »
My controller case is 9 in x 7 in x 2in.  I need the microphone to be fairly small around 1 in x 1 in.
  • Helpful? 12
« Reply #5 on: November 08, 2012, 09:52:06 PM »
  • Helpful? 84
« Reply #6 on: November 09, 2012, 06:13:53 PM »
Is the Audio output 8Ohm from the transmitter/receivers you have?
Can it drive a 1 Watt speaker? Check the data sheet specs.
Is answers are yes then the first speaker will work.
Last post December 06, 2007, 09:45:59 PM
by airman00
Last post January 16, 2009, 12:32:48 PM
by izua
Last post January 10, 2011, 02:46:54 AM
by enekux
Last post February 11, 2013, 08:32:36 PM
by waltr
