Author Topic: toy laser designator/ reflections detector  (Read 366 times)
Offline seandegTopic starter
« on: November 14, 2012, 03:55:33 AM »
Hi to all,
am thinking of making a toy version of a laser designator /reflections detector system.
Environemnt would be a room, robot(tracked probably) to move around floor to seek out the object the reflections are coming from --- such as shiny metal box, plastic block, or a small shiny toy.
The user would designate the destination by shining laser at the object.
Question is really is this likely to be possible ? have not seen any projects doing this. But have come across projects where the 'target' has several laser emitting diodes attached, and detector is made from matching sensors.
I suspect that the intensity from laser reflections is just way too low for sensors to pick up.
Any advice on this much appreciated
Re: toy laser designator/ reflections detector
« Reply #1 on: November 14, 2012, 11:29:23 AM »
Yes, within a normal size room. Modulating the LASER will make things a lot easier.
1 - Google.
2 - Ask specifc questions.
« Reply #2 on: November 15, 2012, 09:14:01 AM »
Thanks Soeren,
I will go ahead with that project now. As it progresses no doubt there will be problems. When I have something specific to ask for advice on, after some researching via google but not getting the answers,  I will return to the forum.
All the best,
Seán
« Reply #3 on: November 15, 2012, 10:17:59 AM »
No way you can fail following that recepie :)
Offline Gertlex
  • Helpful? 23
« Reply #4 on: November 16, 2012, 07:50:32 PM »
I'll just chime in that lasers generally shouldn't be toys. *shrug*
I
Last post January 29, 2007, 10:28:57 AM
by Steve Joblin
Last post June 15, 2007, 03:14:57 AM
by dunk
Last post February 04, 2009, 01:21:52 PM
by amadcow
Last post May 29, 2009, 02:58:06 AM
by rubber
