Author Topic: arduino and ultrasonic  (Read 441 times)
Offline sebastianTopic starter
« on: November 25, 2012, 10:27:54 AM »
I am using a hr-04 4 pin ultrasonic and I want to print the result on an lcd using arduino and this is not working
int distance
distance = so and so
serial.print(distance) // this worked perfectly
lcd.print(distance) // not working
Offline Gertlex
  • Helpful? 23
Re: arduino and ultrasonic
« Reply #1 on: November 26, 2012, 03:12:01 PM »
Does not working mean your code doesn't compile, or just that nothing happens with the hardware when  running the code?
Posting full code will help others diagnose the problem, as well.  You can use [ code ] [ /code ] tags (without the spaces inside the brackets) to make the code easier to read in your post.
I
Last post December 16, 2009, 07:35:26 AM
by karmax
Last post June 24, 2011, 08:44:50 AM
by garrettg84
Last post October 12, 2011, 07:39:51 AM
Last post March 06, 2013, 04:01:30 PM
by srayner
