Software > Software
arduino and ultrasonic
(1/1)
sebastian:
I am using a hr-04 4 pin ultrasonic and I want to print the result on an lcd using arduino and this is not working
int distance
distance = so and so
serial.print(distance) // this worked perfectly
lcd.print(distance) // not working
Gertlex:
Does not working mean your code doesn't compile, or just that nothing happens with the hardware when running the code?
Posting full code will help others diagnose the problem, as well. You can use [ code ] [ /code ] tags (without the spaces inside the brackets) to make the code easier to read in your post.
Navigation
