Author Topic: how to objectively define 'controllability' of underwater robots  (Read 426 times)
Offline AdminTopic starter
« on: November 28, 2012, 12:57:17 PM »
I'm looking for ideas to this research problem I'm working on . . .
Let's say I have a list of 50 different underwater robots. They are all different. Some have many thrusters, some just one. Some have rudders, some have fish tails, some have side fins. Some are like mantarays, some are like fish, some are torpedo shaped and some are box shaped. And some mix/match those attributes.
I know the mass, velocity, and dimensions of most of them, and have a picture of all of them. I do not know their acceleration rates, drag coefficients, nor their control algorithms. I cannot run any tests on any of them.
Given this information, how could I objectively rank them in order of controllability?
Controllability, meaning how easy can it maneuver and to remain stable despite external environmental influences. I can think of a few ways, but they have have caveats and looking for other ideas . . .
Re: how to objectively define 'controllability' of underwater robots
« Reply #1 on: November 28, 2012, 09:34:44 PM »
Assuming some of them are quite similar, I don't think it's possible, as you have no real measure of drag for instance.
Some decades ago, scientists were quite surprised, when tests revealed that the coarse skin of a shark, is actually allowing it to move with less drag, as compared to a perfectly smooth surface and they predicted that ships would be painted with "artificial shark skin" (in an undefined future) to save fuel.
With that, the "no test" and the "objectively rank" in mind, it sounds like you have you work cut out.
And besides... That a subject should be capable of objectivity is an illusion and an oxymoron ;D
Offline Gertlex
  • Helpful? 23
« Reply #2 on: November 29, 2012, 01:04:26 AM »
I could show you pics of super aerodynamic solar cars, and you'd really have no idea of their handling... The car comparison might be poor though... their ratio of interior importance to exterior importance is probably higher than submersibles, if that makes sense.
In other words, I agree with Soeren. But I'm probably just not imaginative enough.
I
« Reply #3 on: December 03, 2012, 04:57:41 PM »
The two ideas I currently have are the turning radius, and counting the degrees of freedom.
Offline Mr. Ninja
« Reply #4 on: December 09, 2012, 11:06:50 AM »
I think (even coming at this as someone with limited experience), that maybe you should factor in depth and water pressure (if you can?). Including the pressure exerted on the sides at their appropriate speeds, factoring in the surface area, radius, and DOF?
I'm thinking that might work but as I said before, I'm not experienced with this sort of stuff.
Last post January 11, 2008, 07:59:13 PM
by SmAsH
Last post March 29, 2009, 11:14:47 PM
by SmAsH
Last post June 15, 2010, 08:08:54 AM
by madsci1016
Last post June 26, 2012, 11:52:48 PM
by roboswarm
