Electronics > Electronics
Servo Issue With Axon
<< < (3/3)
As you may already know, the original Axon can't handle more than 10V because that big blue capacitor is rated at 10V. You can just replace it with a higher rated capacitor (and lower mAh), thereby letting you can use the built-in Axon regulator to do what you wanted. No extra circuit needed.
The Axon II can handle up to 20V because I corrected that "mistake". (I didn't think people would use greater than 7.2V batteries when I designed the original in 2007)
The regulator is the same on both, and can handle up to 1.5A. If it overheats, it will throttle back the current automatically.
Ok thanks everyone for the help
[*] Previous page
