wiring help
<< < (2/2)
--- Quote from: ROVER on December 09, 2012, 11:26:30 AM ---[...] should it be alright to hook it up on one of the outputs of the motor controller?
--- End quote ---
If you give it the right voltage, yes.
Most "cheap" ready built R/C cars have got a DC motor  for steering and mostly without feedback, so it's hard left/right or center.
The black wire on the other motor is likely a ground lead (although it's skimpy), as a motor mounted in a plastic chassis has got no other way to ground the motor housing. Measure the resistance between the black wires far end and the motor housing itself and you'll know for sure.
[*] Previous page
