Author Topic: How to control AC powered device using MCU?  (Read 327 times)
Offline allahjaneTopic starter
« on: December 09, 2012, 09:07:36 AM »
Hi all,
Short explanation:
I give 5v to [power control] --> AC Device ON
I give 0v to [power control] --> AC Device OFF
please advice  simplest & cheapest option for [power control]
P.S>I will not use relays
Long Explanation:
Basically I want to switch the AC (230V 50Hz) powered device on/off as per the MCU signals (Programmed logic ::))
for signalling I have 5v from normal I/O pins
I have considered Mechanical relays but I don't think they could run on the low current from the I/O pins .. further more I do not want to add a motor driver to control the relay as it will make the design  more complicated and much of the power will go for keeping the relays engaged!
So,I am looking for an electronic device/circuit for the purpose such as a MOSFET or something called as TRIAC
But, I am pretty dumb at electronics
can someone recommend a decet way to control the AC power to device using just the 5 v
  • Helpful? 86
Re: How to control AC powered device using MCU?
« Reply #1 on: December 09, 2012, 09:24:25 AM »
Microchip has a few App Notes on controlling AC from micro-controllers.
http://www.microchip.com/wwwcategory/TaxonomySearch.aspx?show=Application%20Notes&ShowField=no
Then the makers of the AC switching devices will have data sheets and App Notes on their usage.
« Reply #2 on: December 09, 2012, 01:37:17 PM »
If you absolutely hate the thought of a relay with a small signal transistor driving it (which is the cheap and easy way), either go for an SSR (Solid State Relay) or make on yourself from a zero-cross switching opto coupler (like the MOC3040, or better the IL410) and a TRIAC.
  • Helpful? 56
« Reply #3 on: December 09, 2012, 08:01:08 PM »
Relay + BS 170 (or other small-signal transistor) seems the most robust, and will give you a galvanically isolated solution. This is important from a safety point of view!
http://www.digikey.com/product-detail/en/G5LE-1A%20DC5/Z3115-ND/369007 ($1.49 qty 1)
I've also used these SSRs myself and they work fine -- but you need a double-insulated box, as it's not galvanically isolated:
http://www.digikey.com/product-detail/en/S216S02F/425-2414-ND/720364 ($6.26 qty 1)
Last post August 21, 2008, 10:20:10 AM
by binu_ji
Last post September 03, 2008, 11:19:15 PM
by pomprocker
Last post October 18, 2009, 01:42:53 AM
by Joker94
Last post July 29, 2011, 06:38:03 PM
by Sylvestre
