Author Topic: Removing parts from real car  (Read 393 times)
Offline salamaTopic starter
« on: December 12, 2012, 11:21:11 PM »
Hello,
my car is going to the graveyard soon, I started thinking is there any parts I might want to remove. I have made one little robot and some arduino projects. I just started thinking is there anything I might want to take for myself from the car. Thank you!
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: Removing parts from real car
« Reply #1 on: December 13, 2012, 02:35:00 AM »
There's catalyst (if there is one) that can be sold as it contains some precious metals. Depending on the year and make it might have electric power-steering column which inside has massive motor and torque sensor (quite expensive part for hobby projects.), also, car has wiper motors, fans, many switches, relays, fuses and loads of wires and LEDs/light bulbs. All control circuits are of no use, unless You're willing to de-solder tons of resistors, transistors and capacitors. All embedded circuits/controllers are not useful as they are most likely made for that specific circuit, hence cannot be reused/reprogrammed using available hobby programmers. Using scrapped car and some bought/built control circuitry You can probably make decent battle-bot or something similar.
  • Helpful? 49
« Reply #2 on: December 13, 2012, 11:04:29 AM »
The speakers can make good robot mouths.
As can the horn :-)
« Reply #3 on: December 13, 2012, 05:10:06 PM »
Further possible motors, actuators and sensors:
Power windows (one in each door)
Central locking motors (one in each door)
Solenoid latch in trunk
Head lamp heihgt adjust motors
Power mirror adjusters
Roof window motor(s)
Automatic anti glare rear view mirror
ISM (idle stepper) and a few other goodies in the EFI system. like a platinum air mass detector
Starter motor and solenoid
Fuel pump
Hydraulic pump motor(s)
Ignition coil
Knock sensor(s)
Oxygen sensor
Power electronics parts in the ECU (integrated or discreete H-bridges)
Last post February 17, 2007, 06:34:22 AM
by JonHylands
Last post March 11, 2008, 08:54:17 AM
by Trumpkin
Last post April 13, 2009, 08:31:14 AM
Last post July 06, 2009, 12:38:56 AM
by SmAsH
