Author Topic: High Voltage Charging Circuit.  (Read 288 times)
Offline SmAsHTopic starter
« on: December 29, 2012, 10:08:57 PM »
Hello Everybody,
Currently i am working on a high voltage application which requires charging a
bank of 450v capacitors to 400v and 5700uf. Currently i am working off the circuit attached, using a flash capacitor charger from a disposable camera and the mains charger, working off 240v 50hz. I do plan to build another battery charger using a flyback transformer, but for now i wish to focus on the mains charger.
Does anyone see any faults with the circuit shown below? Just before i go blowing myself up :)
Cheers guys.
Online jwatte
  • Helpful? 49
Re: High Voltage Charging Circuit.
« Reply #1 on: December 30, 2012, 06:58:25 PM »
You'll want a fast-acting fuse on the mains input.
You probably also want to conformal coat the high-voltage parts to make sure you don't accidentally place your hand on them while charged.
I see no bleed that discharges the capacitors when you're done with them -- self-discharge will do that over time, but a quicker and more assured way might be nice.
There is no way that 4 AA batteries will generate 8A of current AFAIK. Maybe with fresh Lithium cells?
Offline billhowl
  • Helpful? 32
« Reply #2 on: December 31, 2012, 03:59:45 AM »
Are you making Coil Gun?
From 240V AC, you will not be getting 400V, it only about 330 to 340V DC.
Connect a 1 Mage Ohms across the cap for bleeding.
best used a mains transformer with a ratio of 1:1 for safety, and reduces noise signal as well.
« Reply #3 on: January 01, 2013, 12:40:27 AM »
Done, kind sir :)
Also done.
Going to chuck the resistor in as billhowl said, no idea why the 8A is there, expecting much less than that haha.
Certainly is a wee coilgun, i know the mains wouldn't hit 400v, not too fussed about getting it spot on at the moment, moreso just getting it to work, then i can play around with transformers and whatnot after. Cheers for the idea of using a 1:1 on the mains though, probably wouldnt've thought of that one.
Last post July 28, 2009, 08:02:56 AM
by awally88
Last post January 02, 2010, 09:20:57 PM
by z.s.tar.gz
Last post January 24, 2012, 06:49:27 PM
Last post July 22, 2012, 03:45:08 PM
