Author Topic: Is using Transmitter & Reciever from a RC car with Arduino Uno possible?  (Read 373 times)
Offline Robogeek3000Topic starter
     Objective: To make a simple remote controlled omni-wheel robot.
     Specs desired (for RC): At least 1 channel
Can I rip a receiver out of a working remote controlled car and use it with an Arduino board?
  • Helpful? 56
Re: Is using Transmitter & Reciever from a RC car with Arduino Uno possible?
« Reply #1 on: January 01, 2013, 09:15:13 PM »
If the receiver uses "standard" servo PWM control, then yes, you can do that. You will then have to write code to detect the duty cycle of the PWM that comes out of the receiver, and use that data on the Arduino. Using the pin-change interrupt and a microsecond-resolution timestamp ought to make that reasonably simple.
Offline studyembedded
« Reply #2 on: January 07, 2013, 05:49:35 PM »
Yes you can do it. I appreciate jwatte's efforts, thanks guys!
Last post May 17, 2008, 02:28:47 PM
by GHF
Last post December 31, 2008, 12:53:04 PM
by roboboy12
Last post September 29, 2009, 06:00:23 PM
by offy
Last post November 11, 2011, 05:25:12 AM
by Wesley
