Author Topic: Question about picture of avrisp mkII  (Read 2082 times)
Offline garriwilsonTopic starter
« on: July 26, 2007, 11:16:46 PM »
Ok I've been having trouble programming the atmega8. It says programming flash... FAILED! Then it can't connect to programmer. Here is a picture. Is the bottom arrow pointing to the header pin where pin 1 from the programmer is supposed to go? It's on page 24.
http://www.atmel.com/dyn/resources/prod_documents/AVRISPmkII_UG.pdf
« Last Edit: July 26, 2007, 11:17:20 PM by garriwilson »
Offline klaxxon
Re: Question about picture of avrisp mkII
« Reply #1 on: July 27, 2007, 08:39:40 AM »
Yes, I believe the white arrow is pointing to header pin 1.
There is a helpful diagram here:
http://www.societyofrobots.com/robotforum/index.php?topic=1045.msg7804#msg7804
(Do this at your own risk)  Also, I believe that I have hooked my programmer up backwards before, and nothing bad happened.  You could just try connecting it both ways and see which one works.
- Adam
Offline elixier
  • http://www.techiesworld.org
« Reply #2 on: July 27, 2007, 10:24:42 AM »
As from the figure it is an ISp Programmer so for programming the Microcontroller it depends on the pins to which your circuit which you have configured it goes. in the picture only a dummy circuit has been shown.
  Techies Rules The World
« Reply #3 on: July 27, 2007, 12:33:46 PM »
Adam there is only one problem about that diagram. It shows the other end of the cable not the one I'm supposed to plug in!! Who needs that?
Last post July 03, 2007, 06:47:06 PM
by d13
Last post February 12, 2008, 12:26:36 AM
by entwicklungswalther
Last post January 22, 2009, 09:04:16 PM
by airman00
Last post June 23, 2010, 04:21:58 PM
by totalis
