Author Topic: First Robotics Project - please assist!  (Read 287 times)
Offline shuggansTopic starter
« on: January 11, 2013, 08:50:00 PM »
Hello All - I have a motor driver board from here: http://ezoneda.en.alibaba.com/product/585578140-213323747/_original_chip_L298N_font_b_motor_b_font_driven_plate_stepping_font_b_motor_b_font_robot_car_font_b_dc_b_font_font_b_motor_b_font_.html (the green one pictured).
I also have this: http://www.ebay.com/itm/150786681292?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
The problem is: I am a software guy (vb.net) and have no clue how to connect these guys together.  Can someone provide some guidance for me?  I would greatly appreciate it!
-shuggans
Offline Tommy
Re: First Robotics Project - please assist!
« Reply #1 on: January 12, 2013, 08:15:04 AM »
shuggans, at first glance it seems your missing something.
the above device seems to be used to enable rs232 between PC and  a Microcontroller.
the above device seems to be used to drive larger stepping motor from Micro I/O lines.
do you have a microcontroller you plan to use?
because to feel comfortable with software, google "phidgetstepper"
Tommy
« Last Edit: January 12, 2013, 08:26:12 AM by Tommy »
« Reply #2 on: January 12, 2013, 02:23:10 PM »
I bought this motor driver as a cheapo to learn on until I purchase this driver board from dimension engineering:
http://www.dimensionengineering.com/products/sabertooth2x60
Can I use my current MAX232 board to go directly into that sabertooth board?  Or will I still need a micro controller in between?
  • Helpful? 49
« Reply #3 on: January 12, 2013, 03:16:41 PM »
You need a microcontroller. The MAX232 board does UART communications. The Sabretooth does step/direction signal communications. The uC needs to translate. A simple Arduino board, or a Atmega microcontroller (or any other microcontroller, PIC, MSP430, whatever) can typically do this.
Offline Tommy
« Reply #4 on: January 12, 2013, 03:46:35 PM »
shuggans, you should be able to use the Max232 to control the sabertooth using serial interface.
Tommy
Last post November 11, 2008, 12:28:50 AM
by pomprocker
Last post February 03, 2009, 05:02:21 AM
Last post August 03, 2010, 09:00:07 PM
by klims
Last post March 23, 2013, 12:40:55 PM
by Vibblewomp
