Author Topic: VIA EPIA PX10000 Pico-ITX Review  (Read 2517 times)
Offline dunkTopic starter
« on: July 27, 2007, 07:48:49 AM »
http://www.mini-itx.com/reviews/pico-itx/
When idle the PX drew around 14W. Even after extreme CPU load (running Prime95 for an hour) we couldn't get this figure above 16W. The temperature of the board throughout was surpisingly cool - barely warm to the touch under normal operation and only slightly warm under stress.
hrmm. still too power hungry for any of my bots but far lower power consumption than last time i looked at putting a PC on board.
definitely an option for someone who wasn't too fussy about battery life.
Offline JesseWelling
  • Only You Can Build A Robot!
Re: VIA EPIA PX10000 Pico-ITX Review
« Reply #1 on: July 27, 2007, 09:46:35 PM »
x86 every where? Yay Geode!
http://www.fit-pc.com/specifications.htm
It's pc104 so you can expand upon it pretty well... if you are into that kind of thing
If you like PPC I suggest you go with a MPC5200... it's got PWM's and I2C (for easy A2D hookup)
This one is expensive but has low power requirements:
http://www.embeddedplanet.com/products/ep5200.asp
This one is cheep but looks less small robot friendly...
It would be fine for a car or robotic arm... or a robotic armed car...or an armed robotic car garage...
http://www.genesippc.com/efika.php
Offline Tsukubadaisei
« Reply #2 on: July 27, 2007, 11:56:12 PM »
A linux powered robot... my dream will finally come true.
« Reply #3 on: July 28, 2007, 12:07:39 PM »
I've been using Gumstix... if you don't need floating point they work out well...
Offline Bajanick
« Reply #4 on: July 28, 2007, 05:35:21 PM »
Those look pretty cool. How are you using them. Can they be used to control an H bridge and a couple motors?
« Reply #5 on: July 28, 2007, 08:54:35 PM »
The Robostix can. It's an ATmega128. I developed a dual system where the Atmega128 does most of the IO like servos, pwm, a2d and gpio and the Gumstix (32bit ARM) does all the heavy lifting for communication/AI/localization.
Generally when you want to use Linux to make a robot you better have some reason for it though.
« Reply #6 on: July 29, 2007, 09:32:20 AM »
Run multiple tasks.
I do that using my umpc with windows.
Offline Bajanick
« Reply #7 on: July 29, 2007, 09:34:22 AM »
To avoid using windows, that would be the main reason for me.
« Reply #8 on: August 23, 2007, 06:56:55 AM »
I was reffering to the complexity of your robot. Do you need TCP/IP and USB devices an mass storage? Well you probably want to use Linux. Do you just need 2 Analog conversions, a serial port, and 2 PWM signals? Well you can probably do without (unless you need Uber processing ...)
Last post July 19, 2009, 05:29:50 PM
by SeagullOne
Last post November 08, 2009, 10:26:45 PM
Last post September 15, 2010, 07:12:23 PM
by madsci1016
Last post February 07, 2011, 01:08:10 AM
by TrickyNekro
