Author Topic: need help with xbee  (Read 252 times)
Offline ROVERTopic starter
need help with xbee
« on: January 16, 2013, 05:22:20 PM »
I would like to seek help how do I get by using two xbee and its shield and arduino uno
I am using this code to run the dc motor of my remote truck to go forward and backward, I was able to make it move using this code, now I am trying to work it wirelessly using xbee, but I am kinda loss, I thought I could just copy this code again to the other arduino and hooked up the xbee and the shield, any help would be appreciated
const int in1 = 2;    // direction pin 1
const int in2 = 4;    // direction pin 2
const int ena = 3;    // PWM pin to change speed
int pot;              // integer for potentiometer
int fspeed;           // forward speed
int bspeed;           // backward speed
void setup() {
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(ena, OUTPUT);
void loop() {
  pot = analogRead(A0);
  if (pot >= 480 && pot <= 540)
    stop();
  if (pot < 500)
    fspeed = map(pot, 479, 0, 70, 250);
    forward(fspeed);
  if (pot > 520)
    bspeed = map(pot, 541, 1023, 70, 250);
    backward(bspeed);
void stop()
  analogWrite(ena, 0);
void forward(int fspeed)
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  analogWrite(ena, fspeed);
void backward(int bspeed)
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  analogWrite(ena, bspeed);
  • Helpful? 50
Re: need help with xbee
« Reply #1 on: January 18, 2013, 11:13:53 AM »
The XBees are serial devices. You need to hook the XBee on each end to a serial port.
I would recommend using SoftwareSerial on the sending Arduino (on some pins other than 0 and 1,) so you don't get interference with programming the board.
You can use the hardware serial port (pins 0 and 1) on the receiving Arduino.
Then, build a simple protocol, and send commands over the serial wire. A simple protocol might be:
0xEE <command byte> <parameter byte>>
So, a command might be "Set forward speed." Call this 0x01. The parameter is the speed value (0 - 255.) Your sending Arduino would then do something like this:
enum {
  CMD_FORWARD = 0x1,
  CMD_TURN = 0x2
SoftwareSerial ss(...);
void sendForward(unsigned char val) {
  unsigned char data[3] = { 0xEE, CMD_FORWARD, val };
  ss.write(3, data);
On the receiving end, you have to receive and decode commands. You should be getting one byte at a time -- you can't assume that a full command will be coming in in a single read request. The algorithm looks something like:
unsigned char buffer[3];
unsigned char bufptr = 0;
void handle_command() {
  switch (buffer[1]) {
    case CMD_FORWARD:
      ... value is in buffer[2];
      break;
void read_one() {
  if (myserialport has data) {
    buffer[bufptr] = read one byte;
    if ((bufptr == 0 && buffer[0] == 0xEE) || (bufptr > 0)) {
      ++bufptr; // in a packet
    if (bufptr == 3) { // packet finished
      handle_command();
      bufptr = 0;
XBee
Started by Cornelam Software
Last post June 12, 2010, 11:03:44 PM
by lhy_L_P
Last post January 11, 2009, 01:57:59 PM
by Magnus
Last post January 23, 2009, 08:13:46 AM
by flimflap
Last post September 30, 2011, 01:25:52 AM
by Gertlex
