Author Topic: (Advertisement) Cheap Fusion PCB Service  (Read 357 times)
Offline drofanTopic starter
« on: January 21, 2013, 03:33:07 AM »
Hi all,
We are Elecrow, which located in ShenZhen, China. We supply competitive prototype Fusion PCB service. Now, You don't need pay extra fees for your PCB's color any more! There are 6 colors for select - Green, Red, Blue, Yellow, White, Black, all colors are free!  You can select the color you like and make your design more sexy. Besides, all boards are 100%E-Test, of course, this is also free.
We supply:
- 2 Layer 10 * 10cm Max with 10pcs.
- 2 Layer 20 * 20cm Max - 5/10pcs (Color Free). In here, the price of 5pcs absolute will make you surprised.
- 2 Layer 20cm * 20cm Max - 50pcs (Color Free).
PCB with Hasl Suface Finish
PCB with ENIG Suface Finish
Here are the prices for usual dimensions, all prices are base on 2 layer, 1.6mm thickness, Hasl surface finish, and 100% E-Test, colors are free.
5 * 5cm 10pcs  $9.9
5 * 10cm 10pcs  $23.9  weight + 60g
10 * 10cm 10pcs  $23.9 weight + 100g
5 * 15cm 5pcs  $29.4, If your boards are used as prototype, we recommend you select 5pcs, not only for environmental protection but also it will cheaper a lot than 10pcs.
5 * 20cm 5pcs  $37.9
10 * 15cm 5pcs  $42.9
5 * 5cm 50pcs  $37.9
5 * 10cm 50pcs  $69.9
10 * 10cm 50pcs  $101.9
We supply world wide shipping, the turn around time is 7-10days(For DHL) or 15-25days(For Airmail). Another good news is we supply free shipping for order over $50. For more detail please visit Elecrow - Fusion PCB Service.
« Last Edit: January 23, 2013, 07:54:10 AM by drofan »
  • Helpful? 56
Re: (Advertisement) Cheap Fusion PCB Service
« Reply #1 on: January 21, 2013, 12:06:18 PM »
This sounds almost exactly like the service provided by seeedstudio and iteadstudio. The pricing is the same, even. I bet they all use the same PCB board fab.
If they do, then the board quality is OK for hobbyist boards and larger pitches and larger holes, but I wouldn't use it for a fine-pitch precision job. They may say they do 8 mil or 10 mil, but I wouldn't rely on that -- 12 mil and up might be fine. For finer pitches, I'd go with oshpark.com instead, which gives you fewer boards, and a slightly higher price, but much higher quality. (Also, you cannot choose your color at OSH Park. Oh, well :-)
« Reply #2 on: January 22, 2013, 09:34:40 AM »
Might have to try you guys for some boards. Anyone ever used them before?
« Reply #3 on: January 23, 2013, 01:02:10 AM »
Welcome!, we will give you the best service!
Last post November 22, 2008, 03:54:40 AM
Last post August 02, 2010, 09:25:14 PM
by Razor Concepts
Last post November 03, 2011, 02:28:25 PM
by peterb
Last post June 16, 2012, 08:50:16 AM
by firatdede
