//Main Functionint main(void){ unsigned char data; unsigned char data_old; init_devices(); lcd_set_4bit(); lcd_init(); while(1) { Leftmost_white_line = 180- ADC_Conversion(3); //Getting data of Leftmost WL Sensor Left_white_line = 200- ADC_Conversion(2); //Getting data of left WL Sensor Left_center_white_line = 200- ADC_Conversion(1); //Getting data of left center WL Sensor Center_white_line = 256 - spi_master_tx_and_rx(0); Right_center_white_line = 256 - spi_master_tx_and_rx(1); Right_white_line = 256 - spi_master_tx_and_rx(2); Rightmost_white_line = 256 - spi_master_tx_and_rx(3); flag=0; data_binary[0] = white_detect(Leftmost_white_line); data_binary[1] = white_detect(Left_white_line); data_binary[2] = white_detect(Left_center_white_line); data_binary[3] = white_detect(Center_white_line); data_binary[4] = white_detect(Right_center_white_line); data_binary[5] = white_detect(Right_white_line); data_binary[6] = white_detect(Rightmost_white_line); data =0x0; data|=data_binary[0]; data<<=1; data|=data_binary[1]; data<<=1; data|=data_binary[2]; data<<=1; data|=data_binary[3]; data<<=1; data|=data_binary[4]; data<<=1; data|=data_binary[5]; data<<=1; data|=data_binary[6]; data&=0b01111111; _delay_ms(10); // delay to control LCD refresh rate lcd_home(); //lcd_string("WL4 WL5 WL6 WL7"); lcd_print(1, 1, data_binary[0], 3); lcd_print(1, 6, data_binary[1], 3); lcd_print(1, 10, data_binary [2], 3); lcd_print(1, 14, data_binary [3], 3); lcd_print(2, 1, data_binary [4], 3); lcd_print(2, 6, data_binary [5], 3); lcd_print(2, 10, data_binary [6], 3); lcd_print(2, 14, data, 3); switch(data) { case 0b00000100: case 0b00001000: case 0b00010000: case 0b00011000: case 0b00001100: case 0b00011100: velocity(230,230);//straight forward(); break; case 0b00011110: case 0b00011111: case 0b00001111: //sharp right velocity(230,0); forward(); _delay_ms(140); break; case 0b00111100: case 0b01111100: case 0b01111000://sharp left velocity(0,230); forward(); _delay_ms(140); break; case 0b01000000: case 0b01100000://left case 0b01110000: velocity(40,230); forward(); _delay_ms(15); break; case 0b00100000: case 0b00110000: //soft left velocity(80,210); forward(); _delay_ms(5); break; case 0b00000001: case 0b00000011: //right case 0b00000111: velocity(230,40); forward(); _delay_ms(15); break; case 0b00000010: case 0b00000110: // soft right velocity(210,80); forward(); _delay_ms(5); break; case 0b00000000: //reverse stop(); _delay_ms(500); if(data_old==0b00111000||data_old==0b00110000 ||data_old==0b00011100 || data_old==0b00011000 || data_old == 0b00001100) { velocity(255,255); left(); _delay_ms(700); } else { velocity(255,255); back(); _delay_ms(500); } stop(); _delay_ms(500); break; default:// straight(slight left) if(data >64) { velocity(0,230);//turn left forward(); _delay_ms(20); } else if (data&0b00000001) { velocity(230,0);//turn right forward(); _delay_ms(20); } else { velocity(180,150); //slight right forward(); } } data_old= data; } return 0;}
2. My question is how would you know that you have to follow black instead of white now?
Quote2. My question is how would you know that you have to follow black instead of white now?If it is centered on the White line then the inner sensors 'see' white and the outer sensors 'see' black.If then the outer sensors 'see' white and the inner sensors 'see' black Then the line changed from White to Black and the sensor outputs need to be inverted ('complement') to use the same code.
//Main Functionint main(void){ unsigned char data , i ,left_speed, right_speed; unsigned char data_old; int deviation , integration , prev_deviation , correction; init_devices(); lcd_set_4bit(); lcd_init(); while(1) { Leftmost_white_line = ADC_Conversion(3); //Getting data of Leftmost WL Sensor Left_white_line = ADC_Conversion(2); //Getting data of left WL Sensor Left_center_white_line = ADC_Conversion(1); //Getting data of left center WL Sensor Center_white_line = spi_master_tx_and_rx(0); Right_center_white_line = spi_master_tx_and_rx(1); Right_white_line = spi_master_tx_and_rx(2); Rightmost_white_line = spi_master_tx_and_rx(3); flag=0; data_binary[0] = white_detect(Leftmost_white_line); data_binary[1] = white_detect(Left_white_line); data_binary[2] = white_detect(Left_center_white_line); data_binary[3] = white_detect(Center_white_line); data_binary[4] = white_detect(Right_center_white_line); data_binary[5] = white_detect(Right_white_line); data_binary[6] = white_detect(Rightmost_white_line);/* data =0x0; data|=data_binary[0]; data<<=1; data|=data_binary[1]; data<<=1; data|=data_binary[2]; data<<=1; data|=data_binary[3]; data<<=1; data|=data_binary[4]; data<<=1; data|=data_binary[5]; data<<=1; data|=data_binary[6]; data&=0b01111111;*/ _delay_ms(10); // delay to control LCD refresh rate lcd_home(); //lcd_string("WL4 WL5 WL6 WL7"); lcd_print(1, 1, left_speed, 3); lcd_print(1, 6, right_speed, 3); lcd_print(1, 10, deviation+20, 3); //lcd_print(1, 14, data_binary [3], 3); //lcd_print(2, 1, data_binary [4], 3); //lcd_print(2, 6, data_binary [5], 3); //lcd_print(2, 10, data_binary [6], 3); //lcd_print(2, 14, data, 3); deviation =0; for(i=0;i<7;i++) deviation += 5*(i+1) * data_binary[i]; deviation-=20; correction = 2*deviation ; left_speed = 200+ correction; right_speed = 200 - correction; if (correction > 55) left_speed = 255; if (correction <-55) right_speed =255; if(correction >200) right_speed =0; if(correction <-200) left_speed=0; velocity(left_speed,right_speed); forward(); } return 0;}
Started by andreahmed Software
Started by CanElec Electronics
Started by Libraoct7 Electronics
Started by growler Robot Videos
