Author Topic: quadcopter construction and design  (Read 6723 times)
Offline [email protected]Topic starter
« on: January 26, 2013, 10:44:14 AM »
hey folks i am planing to make a quadcopter......
what would be the  best material for the main chasis....?
which sensor should be used for the stability ??? a gyro or a accelometer
and i would need the kalman filter
any input or good tutorials? please post it.....
Offline Gertlex
  • Helpful? 24
    • Index of Oddities
Re: quadcopter construction and design
« Reply #1 on: January 27, 2013, 10:32:53 AM »
Start reading here :)
http://diydrones.com/
I
« Reply #2 on: January 27, 2013, 01:37:54 PM »
Sounds like fun.
Carbon fiber. Aluminum or Titanium could be OK, too.
You need both, and ideally also a magnetometer. Which means you need a 9-degree IMU.
Yes.
diydrones.com
« Reply #3 on: January 30, 2013, 07:20:21 AM »
thanxx !!!!! for the reply.....
can anyone tell me about what's a kalman filter have no idea about it???? i know it requires a lot of math....
is there an other alternative for kalman filter ???
Offline jkerns
  • Helpful? 12
« Reply #4 on: January 30, 2013, 09:35:06 AM »
A Kalman filter is a way to take noisy measurments (accelerations, gyro rate of change) and create estimate of what the actual "state" of your system is (attitude, speed).
Math is a fact of life. Newton (and others) didn't invent calculus just to make life hard for students - they invented it because that is the tool that is needed to describe how the physical world operates.
You don't need to use a kalman filter, but then you would need to design an algorithm to translate from the sensor inputs to the actual state of your quadcopter. If you know the magnitude of the noise the Kalman filter will give you the "optimal" estimate of those states. For other methods you will have to sort out the gains of your estimator on your own.
Offline jkerns
  • Helpful? 12
« Reply #6 on: January 30, 2013, 11:45:25 AM »
The task isn't so much to average or smooth the sensor readings. The task is to determine the quadcopter orientation in space based on the sensor inputs.
Your inputs are accelerations and rotations in three axes, you need to find attitude (in the pitch and roll axes) damp any unwanted rotation (yaw axis) and control the speed in at least one direction.
« Reply #7 on: January 31, 2013, 02:26:15 AM »
once again thanxx for the reply....  :D
can ull suggest me any other algorithm or should i learn kalman filter....????
« Reply #8 on: February 02, 2013, 06:00:12 AM »
found this awesome series of tutorials for the frame construction .....
Basic Quadcopter Tutorial - Chapter 1
