Author Topic: 2 24v motor controllers wired too 1 joystick???????  (Read 332 times)
Offline joefish41Topic starter
« on: January 27, 2013, 02:08:49 PM »
hi, im new to this site and wanted some advice or help! i am building a robot form wheelchair parts, ie, im useing 4, 24volt motors, 2 motor controllers and wanted to wire it all into 1 joystick, ???? can this be done?  any advice or help would be a great help. thanks
  • Helpful? 86
Re: 2 24v motor controllers wired too 1 joystick???????
« Reply #1 on: January 27, 2013, 05:04:42 PM »
Which controllers are you using? Link to data sheet.
Do they have resistive control inputs?
What function do you want the motors to do when the Joystick is non-centered?
This would be fairly easy to do using a micro-controller. the joystick's two pots feed a variable voltage to the u-controller's ADC inputs. Then based of the measured ADC values send info the the motor controllers.
Offline Tommy
« Reply #2 on: January 28, 2013, 05:42:31 AM »
joefish41, if you also got the controller(with a joystick) that came with the motors, you could use that.
the sweet thing about using wheelchair controllers is all the built in safeties.
Tommy
« Last Edit: January 28, 2013, 05:45:56 AM by Tommy »
« Reply #3 on: January 28, 2013, 06:28:22 AM »
hi guys, thanks for the advice, the 4 motors, 2 controllers and the 1 joystick came from 2 identical wheelchairs they are quite old controllers and joystick, they are penny + giles d49464/5 controllers, what i had planed to is use both controller, with both the wiring looms from the chairs  and wire the looms into 1 joystick, speed control  but i wasnt sure if this would work? or if the 2 controllers would be to much for the 1 joystick, speed control, im not that cleaver when it come to electronics as i am new to all this kind of stuff???
Offline Tommy
« Reply #4 on: January 28, 2013, 10:22:46 AM »
joefish41, if both controllers share a common power source I could see it working(IMO 90% chance).
 the P&G controllers are programmed for a particular acceleration/deceleration and speed profiles for
different users, chances are your going to have to have them reprogrammed to operate the same(cost me $50.00Us).
Tommy
« Reply #5 on: January 28, 2013, 01:06:25 PM »
thanks for the advice guys, i will be starting the project in a few weeks, i will keep you updared as the project gose on, thanks everybody
Last post May 07, 2009, 05:27:20 PM
Last post June 05, 2009, 07:27:08 PM
by SmAsH
Last post October 13, 2009, 05:44:32 PM
by Webbot
Last post June 02, 2012, 05:17:05 PM
by vipulan12
