Author Topic: HV Shielding for wheeled robot  (Read 232 times)
Offline stefanbTopic starter
« on: January 29, 2013, 08:18:58 AM »
I am doing an university project that consists in building a robot that operates in a AC to DC convertor. The robot has to work under HV environment. I am looking at possibilities of shielding the electronics of this robot. Can you give me any suggestions or links to look at? Also, will ultrasonic sensors work in such an environment. I could not find any evidence that shows that this is not possible.
Looking forward to hearing from you!!
Many thanks!!!
  • Helpful? 49
Re: HV Shielding for wheeled robot
« Reply #1 on: January 29, 2013, 12:58:08 PM »
Assuming you don't get electric interference, both infrared and ultrasonic sensors should work even though there is a high voltage potential in the air.
Although, if you're building something intended for such an environment, I'd hope that you already had a thorough knowledge of the environment, or involved a professional who does.
Can you build the robot as a Faraday cage, say out of metal wire mesh?
« Reply #2 on: January 30, 2013, 05:53:11 AM »
Thanks for the reply! I am using the NI starter kit. I have shielded the motherboard with conductive material cases and plan to use a grill type screen for the sensors. I am not sure about the motors. I assume that they are shielded. They are PITSCO 12V DC motors.
Otherwise, I plan to build a casing to cover all the robot (as you said a Faraday cage). The problem is that I also have a ZIgBee module with antenna that needs casing. The antenna apparently works under HV environment. I use the ZigBee to control the robot wirelessly.
Stefan
Last post July 26, 2008, 04:58:05 PM
Last post August 20, 2008, 06:26:22 PM
by steferfootballdude13
Last post November 26, 2009, 08:24:33 PM
Last post November 14, 2010, 04:47:56 PM
