Electronics > Electronics
How to determine the angular position of Shaft?
jeeloong:
Dear Robot Experts,
I was wondering if could I attach a potentiometer to the shaft of my gearbox or motor that will enable me to determine the angular position of the shaft since the motor/gearbox does not have integrated encoder or potentiometer build in it.
This is crucial for me to create a exoskeleton suit that is worn by an individual.
Is there any recommendation for the purchase of such devices?
Is there any other device that can do similar thing(determine angular position) like rotary encoder(which is possible for me to purchase separately and connect)
Regards
JL HEE
jkerns:
--- Quote from: jeeloong on January 29, 2013, 05:35:10 PM ---Dear Robot Experts,
--- End quote ---
Yes. It's a reasonably common thing to do.
--- Quote ---Is there any recommendation for the purchase of such devices?
--- End quote ---
Probably about 10K or so would work. I assume rotation is well under 360 degrees for your application.
--- Quote ---Is there any other device that can do similar thing(determine angular position) like rotary encoder(which is possible for me to purchase separately and connect)
--- End quote ---
Yes. You can buy encoders.
jeeloong:
Thank You Very Much for the confirmation! This means my project is feasible.
I would be purchasing Banebots 4:1 P60 Gearbox and RS555 Brushed Motor (Kit) from Banebots United States and get it delivered to United Kingdom either from robotshop or banebots(US). It provides about 47 Nm of torque which should be sufficient for my exoskeleton to actuate the hip. (Currently working out on more accurate way of calculating torque required for walking)
Hopefully able to find decent hollow shaft potentiometer at decent price. Currently my problem is with the seletion of potentiometer and encoder since, I wasn't sure what does it look like and the dimension provided I could obtain the CAD model of it.
The position of potentiometer/encoder is crucial since the suit will be machined(Probably aluminium) for the thigh link and shin link. And there is only 500 pounds sterling to spend. And I have little background knowledge about electrical stuff(From mechanical engineering). Hopefully my friend will deal with the electronic part.
Regards
JL Hee
ErikY:
Just out of curiosity, what type of potentiometer is usually attached to a gear motor for this purpose?
Would it be a linear potentiometer or something else? Also, is there a standard way of attaching this?
jwatte:
You use rotary potentiometers with axles that can mechanically attach.
However, in industrial control you always use optical or magnetic encoders because they are much more robust.
I suggest looking for ready made rotary encoders. Good quality ones complete with mechanical and electronics start at 50 dollars or so.
Navigation
[#] Next page
