Author Topic: Determine angular position of rotating shaft  (Read 294 times)
Offline jeeloongTopic starter
« on: January 29, 2013, 06:00:40 PM »
Dear Robot Experts,
I was wondering if could I attach a potentiometer to the shaft of my gearbox or motor that will enable me to determine the angular position of the shaft since the motor/gearbox does not have integrated encoder or potentiometer build in it.
This is crucial for me to create a exoskeleton suit that is worn by an individual.
Is there any recommendation for the purchase of such devices?
Is there any other device that can do similar thing(determine angular position) like rotary encoder(which is possible for me to purchase separately and connect)
Regards
JL HEE
  • Helpful? 56
Re: Determine angular position of rotating shaft
« Reply #1 on: January 29, 2013, 07:03:47 PM »
I don't like potentiometers for position, because they wear out, have noise, are mechanically challenging to get right, and don't cover a large part of the possible positions.
You can buy encoders and mount them to an arbitrary shaft. This is done all the time in industrial control systems. There are optical and magnetic encoders, and there are absolute and relative encoders. I'd suggest an absolute encoder, so that you don't have to "re-zero" your system each time you turn it on. You can get from some small number of counts per revolution (100, say) up to 16,000 counts per revolution. Obviously, the higher resolution systems are more delicate as well as more expensive.
Allegro makes some nice mid-price magnetic encoder ICs that give you an absolute position with 2000 or 4000 counts of precision. Circuits are about $10 in small quantities. That's just the circuits, though -- you have to mount a magnet and calibrate and drive it yourself. Or you can buy a ready-made integrated encoder with shaft and everything; just hook it up and it works. Expect to pay $50 - $500 each for such a device with reasonable performance and robustness.
Last post August 11, 2009, 05:55:44 AM
by Ro-Bot-X
Last post July 15, 2011, 12:36:53 PM
by growler
Last post October 31, 2011, 11:19:28 AM
by newInRobotics
Last post January 30, 2013, 09:42:56 PM
by jwatte
