Author Topic: wheel resistance and servo torque  (Read 233 times)
Offline morbiusTopic starter
« on: February 07, 2013, 05:45:18 PM »
I've seen the info about calculating the needed torque but the wheel resistance was not considered. A knobby tire on dirt would have to more resistance than smooth tire on wood. Wondering if anyone has done any experiments on wheel resistance - wouldn't want to re-invent the wheel.. tests. ::)
  • Helpful? 84
Re: wheel resistance and servo torque
« Reply #1 on: February 07, 2013, 09:49:19 PM »
The difference in the 'rolling friction' of your two examples is not much and is way less they the basic requirements from Weight, Acceleration and Incline.
The other factor is that you need to design the motor/drive system with a good bit of extra power and torque. Running a motor at its full rated torque all the time is not good since it tends not to last long. (The exception is in some 'racing' or 'speed records' where the motor only needs to last for a short time.)
Also, study motor specs to understand what they mean. For one, they usually state the 'stall torque' and not the torque of maximum power output which is roughly half the stall torque.
Here is some good info on motor specs:
http://www.micromo.com/motor-calculations.aspx
« Last Edit: February 07, 2013, 09:55:04 PM by waltr »
Last post December 09, 2008, 08:11:21 AM
servo torque
Started by crarm Misc
Last post January 10, 2009, 02:11:19 PM
by ArcMan
Last post November 26, 2010, 08:32:07 AM
by waltr
Last post February 06, 2013, 12:47:21 PM
by jwatte
