Author Topic: line follower programming problem  (Read 222 times)
Offline r0b0t1cTopic starter
« on: February 13, 2013, 03:11:19 AM »
Hi. I'm doing a line following robot.
my problem is, in the simulation (pic as below), the code seems like does not work at all.
#include <htc.h>
#if defined(WDTE_OFF)
__CONFIG(WDTE_OFF & LVP_OFF);
#elif defined (WDTDIS)
__CONFIG(WDTDIS & LVPDIS);
#endif
int main(void) {
TRISB = 0X00; //PortB as output
TRISD = 0XFF; //PortD as input
//0
if (PORTD == 0X00)
{ PORTB = 0X00;
//1 Slow Turn Right
if (PORTD == 0X01)
{ PORTB = 0X01; //right motor reverse
PORTB = 0X04; //left motor foward
//2 Slow Turn Right
if (PORTD == 0X02)
//3 Slow Turn Right
if (PORTD == 0X03)
//4 Slow Turn Left
if (PORTD == 0X04)
{ PORTB = 0X02; //right motor foward
PORTB = 0X03; //left motor reverse
//5 Fast Turn Right
if (PORTD == 0X05)
//6 Straight
if (PORTD == 0X06)
{ PORTB = 0X01; //right motor foward
PORTB = 0X03; //left motor foward
return 0;
based on my code, when port RD0 or RDO+RD1 or RD0+RD1+RD2, the motor in out1, will run backward and the motor in out3 will run foward, thus the body will rotate to the left.
but in my case, it does not work. can anyone help me to solve this problem?
thx
Offline newInRobotics
  • Helpful? 46
  • N.I.R.
Re: line follower programming problem
« Reply #1 on: February 13, 2013, 03:20:47 AM »
You forgot Your while(1) loop. Now Your program runs only once and then returns :)
  • Helpful? 56
« Reply #2 on: February 13, 2013, 11:50:56 AM »
The other problem is that you're overwriting your commands.
PORTB = 0x1;
PORTB = 0x4;
This will end up with PORTB only containing the value 0x4, and thus the 0x1 direction won't be moving. You probably want something like:
PORTB = 0x1 | 0x4; // fuse the bits together
« Reply #3 on: February 13, 2013, 05:47:57 PM »
 :o thanks guys..
its working now
by added the while(1) and PORTB = 0x1 | 0x4;  :)
Last post March 25, 2008, 04:34:21 AM
by superchiku
Last post February 03, 2009, 05:02:21 AM
Last post November 08, 2010, 04:38:17 PM
Last post April 15, 2011, 04:00:40 PM
by Aber
