Author Topic: Where to Find "C" Like Wheel Bracket  (Read 377 times)
Offline getSurrealTopic starter
« on: February 13, 2013, 04:59:07 PM »
I'm looking for brackets similar to the ones on the NASA K10 Rover http://lunarscience.nasa.gov/roboticrecon/robotic-tech that would fit on Traxxas RC type wheels.  Anyone seen something like that for sale?
« Last Edit: February 13, 2013, 05:03:13 PM by getSurreal »
Offline sohailsameja
Re: Where to Find "C" Like Wheel Bracket
« Reply #1 on: March 07, 2013, 01:24:37 PM »
if you know exactly how it looks it could me made in any hardware garage
KAMIKAZE CHASER
Online jwatte
  • Helpful? 56
« Reply #2 on: March 07, 2013, 03:25:50 PM »
You're going to have to make or get the brackets separate from the wheel adapters.
RC wheels use one of two standards: Either a fix-pin on a shaft, or a "hex" that goes into the hub. Neither is a standard used anywhere else, where you will have keyways, or D shafts, and/or set screws and shaft collars (and perhaps press fit for bearings.)
For a robot suspension I'm working on, I ended up making adapters from a D shaft with set screw to 14 mm hex center by milling out of aluminum and drilling/tapping holes for the set screws. I then cut the brackets out of aluminum on a mill, too.
« Reply #3 on: March 11, 2013, 10:16:29 AM »
Hey jwatte,
I had replied on your post at pololu about those hubs, which reminds me I did find some more hubs that might work, but I haven't tried them yet.
http://banebots.com/c/WHB
I'll have to go over to that other thread and put the link there as well.
I'm realizing this project will require a lot of custom work.  Oh well, more opportunities to learn and buy new tools.  :D
« Last Edit: March 11, 2013, 10:18:08 AM by getSurreal »
Last post March 25, 2009, 12:12:53 AM
by pomprocker
Last post January 02, 2010, 04:36:54 PM
by SmAsH
Last post July 29, 2010, 05:30:10 AM
by blackbeard
Last post January 19, 2013, 10:05:19 PM
by jwatte
