Author Topic: Making A Robotic Butterfly  (Read 316 times)
Offline BCMagicTopic starter
« on: February 24, 2013, 01:32:50 PM »
I need to make a robotic butterfly (it just needs to sit there, and slowly move its wings every so often). however I know almost nothing about robotics.
Can anyone give advice on how I'd be best to go about it, or good places to learn the robotics needed?
Thanks! :)
Offline Azraels
Re: Making A Robotic Butterfly
« Reply #1 on: February 24, 2013, 02:01:19 PM »
For something that small you should probably use tiny electromagnets to actuate the wings. If your trying to go for realistic size you will probably have to run wires off to some sort of base for power supply. If you can go slightly larger than normal, you could go with one of those tiny solar panels  you see in calculators or perhaps a watch battery to charge a capacitor which dumps its voltage after reaching a certain level to actuate the electromagnets. Google beam bots for that.
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
« Reply #2 on: February 24, 2013, 02:35:28 PM »
Thanks! I had a quick look and Beam Bots seems to be what I was looking for - I'll have to do a lot more research on it.
I was imagining some form of motor, but electro magnets would make things a lot more simple. The butterfly needs to be life sized and self contained, but I might be able to have it sitting on an object, and hide the power supply in there.
  • Helpful? 84
« Reply #3 on: February 24, 2013, 07:17:51 PM »
"Muscle Wire" could also be used to move the wings.
Online jwatte
  • Helpful? 50
« Reply #4 on: February 25, 2013, 03:14:02 PM »
Yes, I was thinking "muscle wire" too. A 555 timer circuit tuned to slow cycle, and some muscle wire, would be enough to build a butterfly that flaps the wings once every 15 seconds or whatever. If you want fancier movement patterns, try an Arduino instead of the timer.
Last post May 06, 2008, 02:30:02 PM
by Asellith
Last post April 01, 2009, 03:31:20 PM
by jellis359
Last post June 10, 2010, 09:14:46 PM
by animeunplugged
Last post August 10, 2011, 04:34:58 PM
by totalis
