Author Topic: Projects blowing up in your face!  (Read 421 times)
Offline AzraelsTopic starter
« on: February 26, 2013, 02:18:48 PM »
Just reversed the polarity on my circuit board. Hit the power, hmm, what is that strange noise, POP!, shards of exploded voltage regulator hitting me in the face. Well its the first casualty of this project, last robot I fried two servos.  :'(
Anyone else ever fry a circuit board?
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
Offline MrWizard
Re: Projects blowing up in your face!
« Reply #1 on: February 26, 2013, 02:47:10 PM »
Its official now, you just joined the club :-)
  • Helpful? 50
« Reply #2 on: February 26, 2013, 02:54:09 PM »
Many times!
The last few:
A 3S 8A UBEC that overheated and a capacitor exploded at a simple 3A load.
A perfboard H-bridge where the narrow pieces of the copper (around the holes) burned out from the load.
Offline Gertlex
  • Helpful? 23
« Reply #3 on: February 26, 2013, 05:42:29 PM »
I used carbon fiber as the chassis material for a bot.  Was doing quick testing with a board not properly mounted to the chassis, and the switching regulator was shorted by the carbon fiber.  Result was a white flash and lots of smoke as some epoxy resin burned.  Regulator works fine, and nothing else was harmed, though :D  (Still replaced the regulator on the bot with a spare one)
I
Offline Jon_Thompson
« Reply #4 on: March 08, 2013, 11:45:00 AM »
All the time! I've fried Arduinos, robots, custom boards, and individual chips over the years. There's nothing like burning the skin off your finger with a µC chip on which you could almost boil water.
A friend of mine has a comedy theory that internally stored "magic smoke" makes electronic components work. When the smoke escapes, the component stops working   ;D
You can still do a lot with a small brain.
  • Helpful? 50
« Reply #5 on: March 08, 2013, 12:20:00 PM »
« Reply #6 on: March 08, 2013, 02:51:31 PM »
  ;D I knew it was true!  ;D
Offline briselec
« Reply #7 on: March 08, 2013, 04:38:16 PM »
Best fry job I've done was many years ago on a wheelchair controller. Had the oscilloscope hooked up to it and put the probe down to go get something. Hadn't noticed till then that one side of the batteries was connected to the frame. As the bare end of the probe landed on the frame half the ICs and tracks went up in smoke. No circuit diagram and no chance of getting one. Took me about 40 hours to get the thing working again.
In assembly language no one can hear you scream
Offline idee17
« Reply #8 on: March 27, 2013, 07:40:22 PM »
Sweet, its not just me that does this...
There are 10 types of people in the world: those who understand binary, and those who don't.
« Reply #9 on: March 27, 2013, 08:53:55 PM »
Fried an LCD panel this week I got from a fax machine. Didn't even get a chance to use it! >:(
« Reply #10 on: March 28, 2013, 04:55:38 AM »
There's nothing like putting the back of your finger against a chip to see if it's "getting a bit warm" only to have the heat remove your skin!  :o
Offline olivthill
« Reply #11 on: March 28, 2013, 05:31:54 AM »
[...] last robot I fried two servos [...]
The first servo that I bought, was a Hitech311. I tested it once and it worked. I did something else, and tried to test it again. I connected it to a breadboard, itsetlf linked to an external source of power and an Arduino. Nothing happened. There was just a little smell of something burning. I quickly removed the servo, but that was too late. I have done new tests and that servo doesn't move. I guess it is fried. Maybe, the polarity was wrong, or there were too many volts. Then I tested servos from other brands and everything was ok. So, I don't buy anymore Hitech servos. I know I am stupid, because there are zillions of people who have no problems with them. This is an absurb fear (or maybe some servos are better protected than others against hazards).
Last post March 24, 2008, 12:35:07 PM
by Asellith
Last post February 22, 2009, 06:50:17 PM
Last post September 22, 2009, 12:16:41 PM
by RoboGeek
Last post December 25, 2009, 09:23:14 AM
by airman00
