Author Topic: Error with programming. AVRISP mkII Urgent  (Read 3503 times)
Offline garriwilsonTopic starter
« on: July 29, 2007, 08:19:53 PM »
Ok, I did everything, I put all the files in to source, header, and the makefile. I clicked rebuild all and it worked like a charm. When I try to actually program the program to my microcontroller, it gives an error saying something like this:
WARNING: FLASH byte address is 0x0000 0x00 ( should be 0x12)
If it says it should be 0x12, then how do I change it? Or maybe that's not the problem? Help!!
Offline yasin
Re: Error with programming. AVRISP mkII Urgent
« Reply #1 on: August 16, 2008, 03:42:43 AM »
I am avrisp mk2 for programming attiny25 ic. in fuses i have used disable reset fuse. A message appeared that mk2  will be inaccessible i clicked ok it programmed once. after that i cant program the ic. can anyone help me with this problem pls...............................?
« Last Edit: August 16, 2008, 03:46:10 AM by yasin »
Yasin J.I.,
Design Engineer,
Engineering Division,
Ammini Energy Systems Pvt. Ltd.,
Industrial Estate, Pappanamcode,
Thiruvananthapuram, Kerala - 695019.
Ph: +91-471-2495588
Fax:
« Reply #2 on: August 22, 2008, 11:28:12 AM »
garriwilson, when you click 'Read Signature' in the AVR Studio dialog, what does it say?
yasin, which fuses did you change? It sounds like you disabled the clock fuse, meaning you 'bricked your AVR'.
Last post July 03, 2007, 06:47:06 PM
by d13
Last post February 12, 2008, 12:26:36 AM
by entwicklungswalther
Last post July 27, 2010, 06:14:51 PM
by Choco_liger
Last post September 07, 2010, 12:41:45 PM
by garrettg84
