Author Topic: Eagle ratsnet issue  (Read 278 times)
Offline Jak24Topic starter
Eagle ratsnet issue
« on: March 02, 2013, 02:33:33 PM »
Hi!
While using the new version of eagle I realized when I make a common ground plane It connects to vias like this:
http://i1325.photobucket.com/albums/u639/warmthofwinter/eagle1_zpsdc5f9a84.png
What should I change so it completely covers it?
Regards
Offline ErikY
Re: Eagle ratsnet issue
« Reply #1 on: March 02, 2013, 03:49:43 PM »
Are your vias named GND?
  • Helpful? 49
« Reply #2 on: March 02, 2013, 07:36:05 PM »
I believe those are "thermals." If you turn off "thermals" then you'll probably get what you want. But your board will possibly have other problems as it's actually being used.
Best is to make the line size of the polygon pour fairly thick. The draw-back of that is that then it won't actually snake its way through narrow openings.
« Reply #3 on: March 02, 2013, 08:06:04 PM »
Thermals make it easier to solder components onto your board. Less metal means less heat drawn away from the joint. I find that thermals make soldering on voltage regulators way easier.
« Reply #4 on: March 03, 2013, 02:52:36 PM »
Is there an advantage for other components?
Wouldn't that decrease the amount of current that can go to that component?
Turned it on and off, didn't work. Would I have to recreate the polygon for the thermals to disable?
Regards
« Reply #5 on: March 03, 2013, 03:26:41 PM »
An advantage to anything that could be hard to solder. If you are hand soldering it isn't a big deal, but really helps for mass production.
Less current, yes, but it can surely still handle more current than your component can. A thermal might bring it from 8A to 4A, but your voltage regulator can't handle more than 1A anyway so no biggie.
I think you can just de-wire than re-wire the polygon and it'll work. I can't remember the exact terminology though, and too lazy to open Eagle to double-check. :P
  • Helpful? 49
« Reply #6 on: March 03, 2013, 07:53:30 PM »
Worst case, you delete the polygon and then re-create it. Although ripup followed by ratsnest typically re-generates the polygon copper layer, so that might be enough. I never turn off thermals, so I don't know the exact incantation that makes it different.
Last post July 29, 2008, 05:57:45 PM
by krich
Last post November 08, 2008, 05:57:15 PM
by sdavis6736
Last post September 05, 2010, 11:43:26 AM
Last post April 11, 2011, 09:19:18 AM
by TheBadger
