Author Topic: xbee, ssc32 e i2c... how to connect them togheter?  (Read 2934 times)
Offline mauro.rollyTopic starter
« on: July 29, 2007, 11:23:31 PM »
Hi!
I am developing a mini robot (a rover with a robotic arm) and I think to use a ssc32 to control the servos, and the md23 (it uses i2c) to control easly the rover. All connected to an xbee, so to control it wireless (wifi) with a Personal Computer.
I would like to know if I can connect all of them togheter in parallel mode or if I need something like some buffers, pull-up resistor, etc?
Thanks in advance for any answer
Best regards, Mauro
Re: xbee, ssc32 e i2c... how to connect them togheter?
« Reply #1 on: August 01, 2007, 05:48:50 PM »
I have built a wireless rover ,my butler robot. Check my blog for info.( the newer version of my robot will be posted soon)
Basically I used a laptop and Phidgets to control relays which control the motor. In your case you could get a mini-ITX board with wireless card attached. But that approach is only if you are going to include devices which require fast processing power on your robot.
If you decide to use the Xbee then look at what this guy did. http://www.shelato.com/SecurityRobot/
« Last Edit: August 01, 2007, 05:49:45 PM by airman00 »
« Reply #2 on: August 11, 2007, 10:01:23 AM »
Sounds like what Im doing . . .
http://www.societyofrobots.com/robotforum/index.php?topic=1218.0
My servos are goin to the digital output pins.
Instead of xbee Im using bluetooth . . . but basically hook that up to the UART.
Last post June 07, 2008, 12:44:57 PM
by flimflap
XBee
Started by Cornelam Software
Last post June 12, 2010, 11:03:44 PM
by lhy_L_P
Last post October 27, 2008, 07:54:57 AM
Last post March 06, 2010, 12:02:51 AM
by bilals
