Author Topic: THE SPURTBOTS?ARE THEY GOOD ANYONE TRIED THEM.  (Read 3796 times)
Offline sohailsamejaTopic starter
« on: March 07, 2013, 04:04:28 AM »
http://m.instructables.com/id/Build-a-SpurtBot-Line-Follower/?ALLSTEPS
http://spurt.pbworks.com/w/page/9145781/Simpelmobil
WHICH ONE WOULD YOU SUGGEST E TO USE THE FIRST ONE(REFLECTIVE SENSOR) OR THE SECOND ONE(LDR)
AND ARE THEY GOOD WITH 90 DEGREE TURNS AND ARE THEY GOOD FOR COMPETITIONS.
« Last Edit: March 10, 2013, 01:05:04 AM by sohailsameja »
KAMIKAZE CHASER
Offline newInRobotics
  • Helpful? 48
  • N.I.R.
Re: THE SPURTBOTS?ARE THEY GOOD ANYONE TRIED THEM.
« Reply #1 on: March 07, 2013, 05:07:10 AM »
Both robots work on the same principle: one motor is on all the time, other motor works only when LDR/Photo-transistor in on white surface. If You post competition track map, we, probably, would be able to tell if these followers are suitable.
« Reply #2 on: March 07, 2013, 05:19:17 AM »
this is the track.
KAMIKAZE CHASER
  • Helpful? 48
  • N.I.R.
« Reply #3 on: March 07, 2013, 05:29:13 AM »
I don't see why it shouldn't work. If follower is going clock-wise - place it on the outer edge of black line, if follower is going counter-clock-wise - place it on the inner edge of black line.
« Reply #4 on: March 07, 2013, 05:43:09 AM »
Thanks alot its an emrgency as i lost my l293d($40 dollar robot)the competition is next week monday so now the big QUESTION is
1)LDR vs REFLECTIVE SENSOR(QRD1114) which is the best choice
2)WHICH IS THE BEST CONIG
1)
2)
« Last Edit: March 07, 2013, 06:51:44 AM by sohailsameja »
KAMIKAZE CHASER
  • Helpful? 48
  • N.I.R.
« Reply #5 on: March 07, 2013, 06:56:18 AM »
I think that IR Emitter/Detector pair is superior to LDR in this application, as it is immune to light other than IR.
« Reply #6 on: March 07, 2013, 07:21:50 AM »
thanks,can i use a pcb instead of a posicle and tires instead of a bearing.
KAMIKAZE CHASER
  • Helpful? 48
  • N.I.R.
« Reply #7 on: March 07, 2013, 09:05:05 AM »
I don't see why not :)
