Author Topic: Using the RMF Calculator  (Read 212 times)
Offline SUTO the GTopic starter
« on: March 08, 2013, 05:09:38 AM »
I am not sure what torque do I have to put at the end (Stall Torque?)
I guess not.  I have to the read torque/rpm curve? But if so, I need the datasheet of the motor. I want to use HS 311-Hitec Standard Servo, but I can`t seem to find the datasheet nowhere on Google. Can someone help me?
« Last Edit: March 08, 2013, 01:27:55 PM by SUTO the G »
  • Helpful? 84
Re: Using the RMF Calculator
« Reply #1 on: March 08, 2013, 06:58:52 PM »
I have used the motor's Stall Torque spec in the RMF calculator and the results seem correct.
To learn more able motors and motor specs see this:
http://www.micromo.com/dc-motor-tutorials.aspx
They also have some good article on gearing, coreless, brushless, and stepper motors under the Technical Library".
« Reply #2 on: March 09, 2013, 02:56:21 AM »
Do you mean that you actually put it in to you robot and it had the desired speed and acceleration?
« Last Edit: March 09, 2013, 04:10:20 AM by SUTO the G »
  • Helpful? 84
« Reply #3 on: March 09, 2013, 09:54:40 AM »
Yes.
Last post February 23, 2008, 01:44:49 PM
Last post December 06, 2008, 01:46:40 PM
by Ro-Bot-X
Last post December 15, 2008, 07:33:31 PM
by silo_xtreme
Last post February 04, 2009, 07:37:58 AM
by TrickyNekro
