Author Topic: help with linear motion  (Read 265 times)
Offline Mr.MTopic starter
« on: March 12, 2013, 12:33:02 PM »
So I need some sort of actuator to provide a straight linear motion.  What first came to mind was using a solenoid but from what I take on them is that they are more of a rapid back and forth motion with no control on how far it extends, where as I need a slow and smooth actuator where I can control the distance.  Am I wrong on how solenoids work? Is there a better option?  This may be simple to others but for some reason I'm stumped. Thanks.
Offline Azraels
Re: help with linear motion
« Reply #1 on: March 12, 2013, 01:46:32 PM »
well did you try googling linear actuators  :P
This was one of the first hits: http://www.servocity.com/html/12v_linear_actuators.html
Im sure there are cheaper on Ebay and just looking around.
If your looking for something tiny, cd players, cd-dvd drives have a small actuator that moves the laser back and forth for reading the disc.
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
« Reply #2 on: March 12, 2013, 02:25:41 PM »
So I need some sort of actuator to provide a straight linear motion.  [...] I need a slow and smooth actuator where I can control the distance.
Have You considered leadscrew? It can be easily made DIY style using threaded rod and a nut. Simply make motor spin threaded rod and see nut moving up and down the thread.
Offline uirobot
« Reply #3 on: April 16, 2013, 02:33:16 AM »
Sure you need a Threaded Rod Stepper Motor with Acme Leadscrew.
  • Helpful? 49
« Reply #4 on: April 16, 2013, 12:00:00 PM »
A "voice coil" might be an option. It's basically a solenoid with position control.
A higher-torque option is stepper motor (or gear motor) with a lead screw and drive nut or bearing. Perhaps coupled with an encoder of some sort. That's how most linear actuators you can buy are built.
Last post February 21, 2010, 07:19:54 AM
by duste83
Last post March 23, 2011, 10:58:05 AM
by nickc
Last post October 22, 2011, 03:23:11 AM
by stopmotion
Last post April 24, 2012, 06:13:29 PM
by Bart_at_Haunted_High
