Author Topic: help with linear motion  (Read 1063 times)
Offline Mr.MTopic starter
« on: March 12, 2013, 12:33:02 PM »
So I need some sort of actuator to provide a straight linear motion.  What first came to mind was using a solenoid but from what I take on them is that they are more of a rapid back and forth motion with no control on how far it extends, where as I need a slow and smooth actuator where I can control the distance.  Am I wrong on how solenoids work? Is there a better option?  This may be simple to others but for some reason I'm stumped. Thanks.
Offline Azraels
Re: help with linear motion
« Reply #1 on: March 12, 2013, 01:46:32 PM »
well did you try googling linear actuators  :P
This was one of the first hits: http://www.servocity.com/html/12v_linear_actuators.html
Im sure there are cheaper on Ebay and just looking around.
If your looking for something tiny, cd players, cd-dvd drives have a small actuator that moves the laser back and forth for reading the disc.
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
Offline newInRobotics
  • Helpful? 48
  • N.I.R.
« Reply #2 on: March 12, 2013, 02:25:41 PM »
So I need some sort of actuator to provide a straight linear motion.  [...] I need a slow and smooth actuator where I can control the distance.
Have You considered leadscrew? It can be easily made DIY style using threaded rod and a nut. Simply make motor spin threaded rod and see nut moving up and down the thread.
Offline uirobot
« Reply #3 on: April 16, 2013, 02:33:16 AM »
Sure you need a Threaded Rod Stepper Motor with Acme Leadscrew.
  • Helpful? 82
« Reply #4 on: April 16, 2013, 12:00:00 PM »
A "voice coil" might be an option. It's basically a solenoid with position control.
A higher-torque option is stepper motor (or gear motor) with a lead screw and drive nut or bearing. Perhaps coupled with an encoder of some sort. That's how most linear actuators you can buy are built.
