Author Topic: IC with h bridges to high current?  (Read 1097 times)
Offline oscyesTopic starter
« on: March 17, 2013, 01:40:27 PM »
Hello everybody thats me again =) i am driving 12 micromotors with a l293d ic for a pair of motors but it happens that the internal resistance of the IC drops my voltage supply across the motors, i am wondering if there is any ic similar to the l293d IC  but with more current capacity or with less internal resistance i need to pass through the IC like 3A
thank you so much hope you know about any H bridge IC which can handdle these Amperes thank you
PD: i need the IC not to be so big i have size limitations =)
Re: IC with h bridges to high current?
« Reply #1 on: March 17, 2013, 04:00:19 PM »
Have you looked at suppliers like DigiKey or Farnell or similar? Note that all the modern chips are surface mount, so if you're not good at soldering surface mount chips, you may need to get a pre-made controller.
Have you looked at Pololu? Here's a good dual-motor driver for 9A per motor: http://www.pololu.com/catalog/product/708
Offline Billy
« Reply #2 on: March 18, 2013, 01:26:57 PM »
LMD18200.
Offline Azraels
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
