Author Topic: Suction effect in robots  (Read 219 times)
Offline VigneshTopic starter
« on: March 21, 2013, 06:54:24 AM »
Hi
I want to make a robot arm that uses suction effect to pick and place objects.
Please provide some idea how to use suction effect to do this.
Note-
1. Placing suction cups on a panel and then lifting the object is rejected.
2. I can use suction pumps but don't know how to do it.
  • Helpful? 49
Re: Suction effect in robots
« Reply #1 on: March 21, 2013, 11:09:53 AM »
You need a thin, flexible plastic hose that extends to the tip of the pick arm. Performance can be improved with some kind of shaped nozzle.
Run the hose to a vacuum pump, with a controlled valve (typically solenoid) in the middle.
When you want to pick something up, move the pick head to the component. Turn on the valve and wait a small amount of time.
When you want to drop something, turn off the valve, and again wait a small amount of time.
Last post January 01, 2007, 11:41:01 PM
by Cognaut
Last post January 23, 2012, 05:42:13 PM
by omkar
Last post February 18, 2009, 09:59:58 AM
by chelmi
Last post April 24, 2012, 08:33:52 AM
