Author Topic: L293D  (Read 1978 times)
Offline m_M321Topic starter
L293D
« on: March 21, 2013, 10:46:31 AM »
I am using the 'Circuit Diagram' on the website:
http://www.electrosome.com/dc-motor-l293d-pic-microcontroller/
The problem is when I connect the ground of the Motor Supply battery the LED for my 5v supply comes on even though that switch is off.
Re: L293D
« Reply #1 on: March 21, 2013, 11:13:10 AM »
The circuit diagram with the microcontroller?
Are you using a pull-down resistor on the motor controller inputs, to make sure there's not a weak pull-up enabling it?
Re: L293D
« Reply #2 on: March 21, 2013, 04:57:40 PM »
thank you for your reply.
yes, the diagram towards the bottom of page w/ micro controller.
I tried 10k pull down resistors on the inputs of the L293(pins 2 & 7) with no change in the results.
Offline Azraels
Re: L293D
« Reply #3 on: March 21, 2013, 10:17:43 PM »
According to the datasheet found here: http://www.alldatasheet.com/datasheet-pdf/pdf/27189/TI/L293D.html
you should have 1 10k resistor going from the 5V logic supply to pins 1 and 9. In your case probably just 1 if you are using one motor.
Also you could pull the other enable to ground if your not using it.
« Last Edit: March 21, 2013, 10:24:08 PM by Azraels »
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
Re: L293D
« Reply #4 on: March 22, 2013, 09:13:36 AM »
Thanks for the reply.
After attempting to applying responses with no change I swapped the L293 out and guess what....no more problem!
