Author Topic: Checking part list to be sure  (Read 1362 times)
Offline SUTO the GTopic starter
« on: March 25, 2013, 08:26:29 AM »
I have made a list of my robot parts and now I want to order them, but since this is the first time I am doing such a thing I would really need your guys help! I want to know if all of my components are compatible with each other, and if there is anything else I need to order to make a functional robot? I have checked it out my self but I am not 100% sure.
Here are my robot`s components:
1.Arduino Uno v3 Dev Board: http://arduino.cc/en/Main/ArduinoBoardUno
2.Turnigy 5 NiMH Turnigy 6 V/ 2300 mA Flat Battery Pack for Servos: http://www.hobbyking.com/hobbyking/store/__25030__Turnigy_LSD_6_0V_2300mAh_Ni_MH_Flat_Receiver_Pack.html
3. HS-311 Standard Servos (3 pcs): http://www.servocity.com/html/hs-311_standard.html
4. Sharp IR Range Finder: https://www.sparkfun.com/products/242
5. Wire for IR Range Finder: http://www.robofun.ro/cabluri/cablu_senzor_3_fire_12_7_cm
6. Breadboard 82x52x10mm: http://www.robofun.ro/breadboard/breadboard-82x52x10
7. Male-Male Wires for connecting the Arduino Board to Breadboard, Servos to Breadboard: http://www.robofun.ro/cabluri/fire_conexiune_tata_tata-240mm
8. Cable USB 1.5m Male A - Male B for connecting Arduino to PC:http://www.robofun.ro/cabluri/cablu_usb_1_5m_male_a_male_b
9.Cable Battery 9V for powering Arduino from 9V Battery: http://www.robofun.ro/cabluri/adaptor_baterie_9v
10. 9V Battery Duracell
11. Wheels 85x24 mm (4 pcs):  http://phoenixmodels.ro/shop/roata-ultrausoara-85x24-p-287.html
12. Material for the body, screws, nuts, glue, etc.
« Last Edit: March 25, 2013, 08:56:47 AM by SUTO the G »
Re: Checking part list to be sure
« Reply #1 on: March 25, 2013, 12:24:00 PM »
You'll need some way to charge that battery, too.
« Reply #2 on: March 25, 2013, 01:17:08 PM »
I thought of simply replacing it! And the Board, the Servos and the Battery Pack for powering the Servos are compatible? I mean will I not fry down something or something else(simply not work)?
Offline Azraels
« Reply #3 on: March 25, 2013, 07:00:11 PM »
Im pretty sure jwatte meant a charger for the 6v battery pack. Your not going to replace that every time it runs down are you?
If your first post is, "I want to build a super complex robot with object recognition, etc..but I have never done programming or electronics...etc."
Your doing it wrong. Start Simple and Work Up.
Offline newInRobotics
  • Helpful? 48
  • N.I.R.
« Reply #4 on: March 26, 2013, 01:22:51 AM »
List looks OK. Although, have You considered how You are going to attach wheel to the servo?
« Reply #5 on: March 26, 2013, 10:16:17 AM »
