Author Topic: Servo control Via Potentiometer wirelessly  (Read 1034 times)
Offline rpowers550Topic starter
« on: March 27, 2013, 05:12:33 PM »
Does anyone know how I could control a servos degree with a potentiometer wirelessly. I though of using a transmitter and receiver, but I havn't found anything promising. I just need to control one servo with one potentiometer, but it wouldn't hurt if I could control more. I need the servo to basically mirror the rotation of the potentiometer for a robot head, and I want to eventually add another potentiometer that can adjust how much the servo will turn from the first POT depending on that the second POT is set on.
Offline Mastermime
Re: Servo control Via Potentiometer wirelessly
« Reply #1 on: March 27, 2013, 05:34:25 PM »
What are using for a controller board as of now?  Arduino?   This is pretty easy using Xbee modules and two Arduino boards, but this requires a lot of extra hardware if you don't have it already.  Someone else may have a better idea
« Reply #2 on: March 27, 2013, 08:18:24 PM »
A RC transmitter/receiver that has a rotating joy stick end (used steering cars) should work right out of the box.
Like these:
http://www3.towerhobbies.com/listings/cat-j.html
