Electronics > Electronics
Line following sensor circuit
I've been experimenting with a white line following sensor circuit using an IR LED and IR phototransistor.
I see that most circuits online are using a 10K resistor for the phototransistor, but I've found this to give really awful response.
A 2K resistor works really well (at the emitter) and gives a full low/high swing when passed over a piece of white Styrofoam.  Any resistor larger than this doesn't work too well.
I don't think the IR parts I'm using are out of the ordinary, so I'm curious about the obvious difference in performance.
QED223 emitter: http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/QED223/?qs=sGAEpiMZZMvAL21a%2fDhxMh7mfA56bpVlGncOq5KiVY4%3d
QSD124 detector: http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/QSD124/?qs=sGAEpiMZZMs50KUSuyRkpqmW%252bYzaTd1qpijOcPsCWn8%3d
I should add that the phototransistor is powered from 5V and I have the resistor (and the output) at the emitter.
