2
Author Topic: Varying Sensor range  (Read 1041 times)
Offline arigidTopic starter
« on: May 02, 2013, 05:02:40 PM »
I had a digital IR Sensor, which gives a high at 10 cm, is there a way to connect resistors, such that the range can be varied a little, to get a HIGH Value at 6-7 cm?
Thanks for any help!
Offline Duane Degn
Re: Varying Sensor range
« Reply #1 on: May 02, 2013, 05:49:57 PM »
Without telling us which digital sensor you're using there's no why to answer your question.
I assume from your other thread your using one of these.
http://www.pololu.com/catalog/product/1134
In which case I believe the distance characteristics are based on the emitter and lens geometry so there isn't a simple way to change its range. I do see there is a sensor with a 5cm cutoff instead of the 10cm. You could use the other sensor if you don't like the 10cm cutoff point.
« Reply #2 on: May 02, 2013, 08:52:15 PM »
Or you could mount the sensor recessed by 3 centimeters.
