Author Topic: Cannot compile Photovore_v1 source code  (Read 1309 times)
Offline Please_DeniseTopic starter
« on: May 04, 2013, 01:01:14 AM »
I would like to explore all of the possible things that the $50 photovore robot can do since I have by far more experience and creativity in Programming than electronics. . which i basically learned from video game modding.
In all my excitement, I encountered a problem trying to compile the source code for Photovore_v1
When I press Build it doesn't do much it's pretty much stuck at
Build started 4.5.2013 at 18:52:23
No error messages . No success messages . I'd rather have one or the other  :'(
Re: Cannot compile Photovore_v1 source code
« Reply #1 on: May 19, 2013, 04:13:54 PM »
Anyway , I finally solved the problem . I guess I just missed the Rebuild All command in the Instructions .
All I gotta do is glue the potheads using a liquid superglue . The Gooey superglue that I used before is crap , those little scrolls are so sensitive it's freaky . . . I had to unsolder the circuit and have take them out completely to avoid having to open it up all the time. They move about 0.02 degrees out of position by themselves if you just wait about 8-12 hours .
