Author Topic: Pressure sensor on the sole of the robot?  (Read 2611 times)
Offline ZhourTopic starter
« on: August 02, 2007, 10:09:39 PM »
Right now I'm going to make a legged robot.
I'm planning to make it competent to walk on surfaces that is a bit bumpy.
It seems that I need to put a pressure sensor, or at least a pressure switch(with a threshold pressure, I think) on the sole,  so that the controlling program can use the value returned from the sensor to judge whether the servo is going to rotate or stop.
Obviously the reaction time of the sensor must be short enough.
Any advice for what I should use for this purpose?
Thanks a lot.
Offline Robotboy86
Re: Pressure sensor on the sole of the robot?
« Reply #1 on: August 03, 2007, 04:15:48 PM »
You mean a sensor that will detect above normal resistance on the servo??  So that when your placing the foot downt hat you can detect when it hits the floor?
If so, you got a few different choices, you could That might work somewhat, but would probaly have flaws.
You couldput a bump sensor there and have it hooked to the bottom that when the bottom hits something, bump switch goes off.
THat could work..  it would be a near instant reaction time to the sensor, but your MCU would depend on how effective it is.  Whether or not you hook it into an intterrupt would matter as well.
k
good luck
Offline JonHylands
« Reply #3 on: August 04, 2007, 09:32:51 PM »
Thank you, Robotboy86 and Jon.
Since in the mechanical design the feet of the robot is supposed to be somewhat like a stick,  it seems to me that both the bump sensor and the pressure sensor are demanding a larger area of contact than the bottom of the stick.Therefore they are somewhat unworkable.
One of my friends suggests using buttons which can often be seen on electronic dictionary. By putting the buttons under the feet we can get to know whether a foot has touched the floor.
In my opinion we don't need to measure the pressure exactly. In stead, knowing whether a foot has touched the floor would be enough for motion controlling.
« Reply #4 on: August 04, 2007, 10:12:27 PM »
You could measure the same impact in the other end of those sticks, as long as they're rigid - perhaps that gives you better room for sensors.
« Reply #5 on: August 05, 2007, 06:42:36 AM »
Perhaps an accelerometer located on the ankle that detects high shocks?
Last post June 07, 2008, 11:51:27 PM
by rahulisola
Last post July 01, 2011, 11:35:19 AM
by Webbot
Last post August 30, 2012, 10:47:09 AM
by TrickyNekro
Last post March 26, 2013, 09:40:41 PM
by Mastermime
