2
Author Topic: VIBRATION SENSOR?  (Read 1204 times)
Offline strat321Topic starter
VIBRATION SENSOR?
« on: May 20, 2013, 08:21:54 AM »
I am looking into using a vibration sensor a source of input, much like a vrbot.  Does such a device exist? Could it be used with the axon ii?
Thanks!
Offline Jon_Thompson
Re: VIBRATION SENSOR?
« Reply #1 on: May 20, 2013, 09:41:10 AM »
Assemtech make some excellent non-directional vibration sensors in both nornally closed and normally open configurations. They're very small and quite cheap. Just hook them up and away you go. They'll take TTL levels.
You can still do a lot with a small brain.
« Reply #2 on: May 20, 2013, 11:22:25 AM »
Another kind of sensor that works well for vibrations in the 10 Hz and below range is accelerometers, available as I2C chips in fairly affordable carriers.
Note that every smart phone for the last few years have been using these as input, so I'd say it's proven to work OK :-) The main thing to watch out for is telling "normal" vibrations of movement from the kinds of vibrations you want to detect.
« Reply #3 on: May 21, 2013, 06:57:13 AM »
I appreciate these responses and will investigate. However with the I2C, I believe this would not work because i will use it to detect and analyze low level surface vibrations
« Reply #4 on: May 21, 2013, 11:26:13 AM »
Before you say "it won't work," you need to specify the parameters you need.
What sensitivity (in gs) do you need? Is 1/100th of a g sufficient? 1/1000th of a g?
What frequency of vibrations do you need to detect? 1 Hz? 10 Hz? 10 kHz?
Once you know this, you can look at the data sheets for the various sensors and accelerometers available.
Offline olivthill
« Reply #5 on: May 21, 2013, 04:27:12 PM »
Some accelerators have analog voltage outputs, instead of I²C, such as this one http://www.pololu.com/catalog/product/1246
But there are a little more expensive than piezo devices such as this one http://www.robotshop.com/sfe-piezo-element-2.html or that one  https://www.sparkfun.com/products/9198
« Reply #6 on: May 22, 2013, 03:52:42 AM »
What if I wanted to hook it up to a device such as an easy vr bot, in place of a microphone perhaps.  Would a piezo element sensor with analog stereo leads fit this bill?
