need sumo bot help for a complete newbie
(1/2) > >>
yerok16:
hi i am new to this forum and are looking to uild a sumo bot. i have read the tutorial andwas wondering a few things. were o i get the circuit board and can i use the robot x chip instad of the one  you used and if yes would i need to re design the pcb and if i had to were can i get info on desining pcbs
yerok16:
hi i read the sumo bot tutorial on this site and found it confusing can any one give me a few pointers in the right direction to get me going
hazzer123:
Which bits were confusing?
SomeSaba:
Yes:
If you are looking for a kit to get started i can point you to:
(in order of most-expensive to least)
Parallax Sumo: http://www.parallax.com/detail.asp?product_id=27400
MARK III: http://www.junun.org/MarkIII/Info.jsp?item=27
Sumorove: http://www.solarbotics.com/
But id actuallly suggest reading the $50 robot tutorial, that will explain a lot.
$50 robot: http://www.societyofrobots.com/step_by_step_robot.shtml
Reccomended Articles by Admin: http://www.societyofrobots.com/toparticles.shtml
SomeSaba:
--- Quote from: yerok16 on August 02, 2007, 10:32:07 PM ---were o i get the circuit board
--- End quote ---
Radioshack sells those pre-punched PC boards and also a PCB etchant kit to design your own board.
--- Quote --- and can i use the robot x chip instad of the one  you used
--- End quote ---
Yes, consult your chip's datasheet for the pins
--- Quote --- and if yes would i need to re design the pcb and if i had to were can i get info on desining pcbs
--- End quote ---
Other people on the boards can give you better info on this one. You have two choices:
1.The pre-punched: http://www.radioshack.com/product/index.jsp?productId=2103800&cp=2032058.2032230.2032265&parentPage=family
2. or http://www.radioshack.com/product/index.jsp?productId=2102870&cp=2032058.2032230.2032265&parentPage=family
There's some software out there where u can design your circuit board and print it out and somehow transfer it onto the copper board, or i think u can use a marker and draw it out b4 u etch it :P. the more experienced ppl on this board can point you in the right direction
Navigation
[#] Next page
