Author Topic: need sumo bot help for a complete newbie  (Read 3539 times)
Offline yerok16Topic starter
« on: August 02, 2007, 10:32:07 PM »
hi i am new to this forum and are looking to uild a sumo bot. i have read the tutorial andwas wondering a few things. were o i get the circuit board and can i use the robot x chip instad of the one  you used and if yes would i need to re design the pcb and if i had to were can i get info on desining pcbs
sumo bot for a newbie
« Reply #1 on: August 04, 2007, 01:14:08 AM »
hi i read the sumo bot tutorial on this site and found it confusing can any one give me a few pointers in the right direction to get me going
Offline hazzer123
Re: sumo bot for a newbie
« Reply #2 on: August 04, 2007, 02:24:36 AM »
Which bits were confusing?
www.icrobotics.co.uk
Offline SomeSaba
« Reply #3 on: August 04, 2007, 02:28:22 AM »
Yes:
If you are looking for a kit to get started i can point you to:
(in order of most-expensive to least)
Parallax Sumo: http://www.parallax.com/detail.asp?product_id=27400
MARK III: http://www.junun.org/MarkIII/Info.jsp?item=27
Sumorove: http://www.solarbotics.com/
But id actuallly suggest reading the $50 robot tutorial, that will explain a lot.
$50 robot: http://www.societyofrobots.com/step_by_step_robot.shtml
Reccomended Articles by Admin: http://www.societyofrobots.com/toparticles.shtml
Offline SomeSaba
Re: need sumo bot help for a complete newbie
« Reply #4 on: August 04, 2007, 02:38:41 AM »
Radioshack sells those pre-punched PC boards and also a PCB etchant kit to design your own board.
Yes, consult your chip's datasheet for the pins
Other people on the boards can give you better info on this one. You have two choices:
1.The pre-punched: http://www.radioshack.com/product/index.jsp?productId=2103800&cp=2032058.2032230.2032265&parentPage=family
2. or http://www.radioshack.com/product/index.jsp?productId=2102870&cp=2032058.2032230.2032265&parentPage=family
There's some software out there where u can design your circuit board and print it out and somehow transfer it onto the copper board, or i think u can use a marker and draw it out b4 u etch it :P. the more experienced ppl on this board can point you in the right direction
« Last Edit: August 04, 2007, 02:39:38 AM by SomeSaba »
« Reply #5 on: August 04, 2007, 04:28:35 PM »
check this out too:
http://www.societyofrobots.com/robot_parts_list_microcontrollers.shtml
