Author Topic: Monster Servo 625 kg.cm with 0.19 sec 60degree  (Read 1274 times)
Offline Ai-botTopic starter
« on: June 01, 2013, 02:18:43 AM »
Hi.
It has been awhile since I posted. Busy with stuff.
I am designing a servo right now.
Asking the manufactory to do some part for me, but it's expensive for only making a few of them.
Anyone interested give me a shout, hopefully, the more I do it will be cheaper to manufact from the company.
These are the spec.
Weight: 450g
Torque: 625kg.cm (8687 once.inch) at 7 volts
speed: 0.19 sec in 60 degree..... :-* at 7 volts
Rotation: 360 degree default ( but can make 180 degree too)
Gear: All metal gear, except for 1 nylon
control: Servo type (plug in as any futaba or hitec)
Voltage: 6-9 voltage ( recommend 7.2V)
Size: (sort of large servo)
Weight: 450g
Length:122mm
Height: 42mm
Width: 45mm
If you have any question post here, if you want it post it here.
Hopefully, the more I do, it wil be cheaper to manufact.
Hopefully, the protype will be done in 2 weeks.
Option:
Potentiometer Magnetic Induction or the regular Potentiometer... Need to find a cheap supplier for Magnetic potentiometer.
(haven't decided which one to use in the servo..... what ever cheaper)
Anyway
Thank for reading.
