Author Topic: About “OMNI-WHEEL ROBOT - FUZZY” control  (Read 1254 times)
Offline primekingTopic starter
« on: June 18, 2013, 09:37:22 PM »
void main()
   long int t=0;
   //initialization
   cereb_init();
   scan(-totalangle/3+scanmod);
   while(!button(A));
   while(1)//code below here only
      sensor_read();//sense
      interpretworld();//plan
      //orient(rotate_speed,trans_angle,0);//speed modified in transpathplan
      //printf("rot:%ld tangle:%ld magnitude:%d\r\n", rotate_speed, trans_angle, trans_speed);
      IRprintmap();
      delay_ms(200);
      //circle test
      /*printf("%ld\r\n",t);
      orient(0,t,0);//rotate_speed, trans_angle, trans_speed
      delay_ms(11);
      t++;
      if (t==360)
         t=0;*/
    while(1);
This main function is copy from "PIC 16F877 source code for omni-wheel robots" .
I can't find it called about whitch function control servos!
Can you help me understand this source code? Thanks!
Source code url: http://www.societyofrobots.com/downloads/fuzzy_C_source_code.zip
Offline newInRobotics
  • Helpful? 48
  • N.I.R.
Re: About “OMNI-WHEEL ROBOT - FUZZY” control
« Reply #1 on: June 19, 2013, 01:02:50 AM »
I assume it's the "orient(0,t,0);//rotate_speed, trans_angle, trans_speed" function.
« Reply #2 on: June 19, 2013, 05:56:04 PM »
Thank you your reply!
the function orient will not be execute ,because it was contain in "/* */.
