Author Topic: power supply question  (Read 1015 times)
Offline nanotechopolis_grTopic starter
« on: July 01, 2013, 03:27:57 PM »
hi all!
i have a device that has 2 usb 2.0 outputs one @1A and the other @2A  , its possible to connect them? i mean the +5v into one or its any danger from the diferent current? the use that i want to do is to power up some servos that works at 7V! is there any way with regulators if the above exist? or i have to use them separetaly?
thanks !
"On the 29th of May, the last day of the siege, our Lord God decided, to the sorrow of the Greeks, that He was willing for the city to fall on this day into the hands of Mahomet Bey the Turk son of Mu
Re: power supply question
« Reply #1 on: July 01, 2013, 08:00:19 PM »
You cannot connect them in series, to generate 10V, if that's what you want to know.
You may or may not be able to connect them in parallel, depending on specifics of the implementation.
Note that the A rating is "max power deliverable" -- power supplies do not "push" amps into circuits; circuits "draw" amps, and if they try to "draw" more amps than the rating, something will go "squish." (That's a technical term :-)
« Reply #2 on: July 02, 2013, 03:02:24 AM »
thanks    jwatte !  :)
