Author Topic: DC Motor  (Read 1573 times)
Offline robonerd137Topic starter
DC Motor
« on: July 03, 2013, 10:51:47 AM »
I am trying to control the speed of a DC motor with a micro controller. Can someone reply with some resources?
Offline nanotechopolis_gr
Re: DC Motor
« Reply #1 on: July 03, 2013, 03:23:48 PM »
you can use PMW !
the functions are:
1)PWM1_Init(constant long frequency) initialize the frequency parameter
2)PWM1_Set_Duty(unsigned short duty_ratio) to set the cycle , the value can be 0...255
3)PWM1_Start() for starting the PMW output
4)PWM1_Stop() for stoping the PMW  output
you can also google it! check this http://www.electrosome.com/dc-motor-speed-control-pic-pwm/ for further details
"On the 29th of May, the last day of the siege, our Lord God decided, to the sorrow of the Greeks, that He was willing for the city to fall on this day into the hands of Mahomet Bey the Turk son of Mu
Re: DC Motor
« Reply #2 on: July 03, 2013, 04:05:17 PM »
thanks so much! this will really help with my project
Offline newInRobotics
  • Helpful? 48
  • N.I.R.
Re: DC Motor
« Reply #3 on: July 04, 2013, 02:25:57 AM »
You didn't tell us what microcontroller You are using.
Re: DC Motor
« Reply #4 on: July 04, 2013, 07:50:52 AM »
Or what programming language.
Or which motor and its specs: Voltage, Current draw.
And if the motor draws more than a few 10's of mA then you need a driver circuit.
Do you the motor to run in both directions (CW & CCW)? or just one direction?
This will determine if a simple transistor switch or a full H-bride is required.
